Linking an equation value to a Property Field
I'm pretty certain this is possible - I just haven't found the right path yet... How do I link an equation value - for example - 'Total Length' - to a part's property? I know how to add 'Total Length' as a lone value, but I want to link the Description field = STUD,'A'X'B'X'Total Length'
RE: Linking an equation value to a Property Field
Unfortunately, with standard SW functionality, you can drive a custom property by an equation, but only if the result of the equation is a number. Concatenated strings are not possible. You will need to use VBA in an equation to set the value. There's a SolidWorks World presentation on that by Josh Brady.
-handleman, CSWP (The new, easy test)
