Manual Entry Field in a Repeat Region Table
The title pretty much says it all.  I have been asked if I can add a "notes" field to our standard BOM table, which is currently an automated repeat region table.  The notes would be unique to each drawing (possibly to each PAGE in a drawing), so I cannot simply add a parameter to the parts.
Using Pro|ENGINEER Wildfire 4.0 M190 and Intralink 3.4 M062 on Windows 7 Enterprise 64-bit.
RE: Manual Entry Field in a Repeat Region Table
Just add a column and then manually add the text you want for your notes. Even though the table is repeat regions, you can override individual cells.
Ben Loosli
If you add a column to your repeat region, you can then define that column (cell) as a "Comments" column under the Repeat Region menu.
<tg>
