NX5 32 bit or NX5 64 bit
Is there and easy way to check which version is installed on a PC.  We have a 64 bit PC that is supposed to be loaded w/ 64 bit NX5, and I just need to verify that it isn't the 32 bit version.
RE: NX5 32 bit or NX5 64 bit
Help -> About NX -> System Information
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
The 'System Information' dialog won't provide that information, however if you go to...
Help -> NX Log File
...in the first few lines of the listing, right under where it shows the description of the 'Machine type' and the 'OS', there will be a line that indicates which 'version' of NX that you're running, "32 bit" versus "64 bit".
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
The system info for NX6.0.2.8 will list the OS Version, including x64 or x32 (at least it does on my box).
That may be true of the OS version, but this does NOT indicate what the NX version is.  Obviously, if the OS is 32-bit, then the NX version must also be 32-bit.  However, if it's a 64-bit version of the OS, you could still be running the 32-bit version of NX, which I think is what the original question was really asking about.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Right as usual, John.
Thanks for the replies.  John, your solution was exactly what I needed, thank you!
