Cropping Problem
Cropping Problem
Cropping Problem
I created an auxillary  view and cropped a portion of it because I did not need to show all of the view for clarity. I added a few fillets to the associated model and added nomenclature to the drawing and the previously cropped view is now showing the full view. When I click on the view the box shows the view as cropped.
Any help would be appreciated.
RE: Cropping Problem
Edit the sketch of the crop and then click the rebuild icon.
What version are you using?  I used to see this more often in earlier versions.  I would see it with detail views as well... just once in a while.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Thanks ShaggyPE, that did the trick. Appreciate the tip.
