roof dimension?
roof dimension?
I have an equipment that needs roof.
No Siding.
Where can i get reference for roof length, width and height based on equipment dimensions.
No Siding.
RE: roof dimension?
RE: roof dimension?
Why do you show a sloping roof?
Are you prepared to allow rain to hit the top of the equipment under strong wind conditions?
Does the eqipment give off heat?
What kind of equipment is it?
BA
RE: roof dimension?
no i dont need to service from the top.
equipment department wants it protected from rainfall.
wind borne rain was my concern since this is not enclosed.
so i am looking for a guide so i wont oversize/undersize the roof.
equipment is about 20 ft length by 1 ft width by 6 ft high.
it's also kinda tight in there. see pic. green equipment. blue roof.
RE: roof dimension?
RE: roof dimension?
BA
RE: roof dimension?
RE: roof dimension?
RE: roof dimension?
RE: roof dimension?
BA
RE: roof dimension?
If they just want to cover it for the service people during rain, then size a cover for an angle from it's base of 45-60 degrees to the edge of the cover and get them to approve the size.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
RE: roof dimension?
Mike McCann
MMC Engineering
RE: roof dimension?
if you oversize: if they'll complain, it'll be only once: when the bill comes.
if you undersize: you'll hear about it every time again.
