Replacing MG set
Replacing MG set
Hi all,
So we have an old, old equipment from the 40's that is using an MG (motor-generator) set. We are thinking about replacing this MG set with a solid-state power supply or another MG set with today's motor technology. What do you guys think?
Inputs:
-30kW, 3 phase 440V, 60Hz
Output:
-90-240V, 1 phase, 180Hz
-124VDC
Inputs:
Output:
-124VDC
RE: Replacing MG set
The DC supply can be gotten from a small rectifier in any case, or is that the exciter for the 180Hz generator?
rasevskii
rasevskii
Companies who make 400Hz ground equipment for the aviation industry might be able to make you a 'special' although the following equation tends to be fairly accurate: aviation supplier + custom build = very expensive.
