Unable to Drag Datum Symbol Away from GTOL
I have had this happen to me a few times and can never figure out why it is doing it or how to rectify it.
I attach a GTOL to a surface, with a leader. I also have a datum plane running through that surface, on which I click>RMB>properties>Placement 'In Gtol'.
It gets attached to the GTOL box underneath it as I expect it to. BUT for some reason, I cannot always select it and drag it down so that it shows the triangle properly. It just seems unpickable and undragable, which is no good for a drawing that is to be used.
See image for the state it gets stuck in...
Any help REALLY appreciated!
Thanks.
Thanks.
Jon Reynolds
RE: Unable to Drag Datum Symbol Away from GTOL
There is a setting in the drawing options that will set the datum extension to a larger preset value. I believe it is set_datum_leader_length. Also have you tried the selection filter set to datums? I have noticed before on my own drawings that in order to select the datum tag to move it I have to select the datum itself first not just the tag. The datum can be selected in the drawing tree under the view which it is located.
Hope something works out,
- J -
Here's a strange development, if I place the GTOL as a free note, I can select the datum flag and drag it. If I reattach it with a leader to a surface, it reverts to the image I posted... on top of GTOL box and unselectable!
Jon Reynolds
Jon Reynolds
Hope it works out,
- J -
