Polishing notes on a drawing
Hello, everyone,
I am looking for a reference to the definitions of P1, P2 and P3, which describe the levels of polish applied to one or more faces. From memory, P1 means remove gross defects such as scratches and P3 is a mirror finish, with P2 somewhere in the middle but can anyone be more specific?
Thanks in advance,
Jon
Thanks in advance,
Jon
JHTH
NX 7.0.1.7 + TC 2007
RE: Polishing notes on a drawing
I can't recall any "grades" being specified or discussed in ASME B46 or Y14.36, so maybe it's a ISO thing as shown at http
Why not just call out the surface finish requirement in terms of Ra, Rz, etc? I figure any "grade" will eventually point back to a quantifiable level of finish.
Of interest may be the standards for surface finish, see the Wikipedia article, which has references to the relevant ASME and ISO standards. Note that one of the callouts for "lay" (which would go inside the square root symbol for surface finish) is a "P" - for particulate:
http://en.wikipedia.org/wiki/Surface_finish
I'll try to contact someone there but in the meantime if anyone can advise on this I'd be very grateful.
Jon
JHTH
http://re
However I am not sure if this is what you are looking for.
Cheers,
Jon
JHTH
