Extrude Up to Faces
Extrude Up to Faces
I'm trying to extrude a rectangle to a set of faces but depending on which one I pick, the extrusion matches one and falls short of the other, or the extrusion matches the one and goes through the other.
How can I get it to extrude flush to a set of faces, not just one.
I've attached a screenshot of what I'm talking about. Hopefully it illustrates my question.
Thanks in advance
Thanks in advance
RE: Extrude Up to Faces
www.compositescentral.net
"Try copying the surfaces of interest (e.g. offset w/ zero distance), then extrude up to the surface body. "
What do you mean by copying surfaces of interest? Thanks for the tips!
Attached is a picture of the part I'm trying to model. It's some clip that came with a TV my dad bought and I thought it would be good to learn how to model it.
These are a little old and out-of-date, but might help
http:/
