forcemain discharge to pond
I have a pumped stormwater forcemain that discharges into a pond via a 4 inch pipe above the pond water level. The discharge velocity is so powerful that it shoots the water about 10 feet at a fairly high pressure and has started to erode the pond bottom. I have been tasked with fixing this issue. I don't know the flow and the pressure in the forcemain and the pump is constant speed. I am thinking just to increase the last 20 feet of pipe to 18 inch diameter or so to slow the velocity down to basically a standstill and then the water will just fall immediately into a rip rap basin. Do you think this will work or do I need something like an orifice plate in the line as well to reduce the pressure? Any help is appreciated. Thanks.
RE: forcemain discharge to pond
an orifice plate will reduce the flow and increase the pump head, probably not useful. 18 inch is probably too large, you need to maintain a minimum velocity of about 2 or 3 fps to move solids. the most common solution is to discharge into an energy dissipater instead of just shooting it into the pond.
Another option is to turn discharge up and create aerated discharge...helps for a variety of reasons.
What is usually used in this application is a simple multi-port diffuser. You can fabricate a 4-Inch submerged diffuser 5-6 feet long that should be comprised of approximately 10 ports with each port being a 2-Inch diameter pipe. Attach the submerged diffuser onto the end of the existing pipe.
If you have about 250 gpm in the 4-Inch pipe, that will give you a velocity of approximately 2.5 ft/sec out of each of the diffusers.
Here is a link to examples.
http://www.cormix.info/CORMIX2.php
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
