how to make a worm drive mating
okay people, this is simple: i must model the worm drive as it is - with proper teeth meshing, exact axes distance and proper rotation and so on...
How this can be done ? Mates, physical dynamics and so on - please explain it
hope the attached file is ok
RE: how to make a worm drive mating
dkastz,
   How good does your model have to be?  I can accurately model a worm.  I can accurately model the position of the worm and the worm gear.  I would use a spreadsheet to analyze the system.  The worm gear is tough.
   Your worm gear ought to be fabricated by a gear cutter.  In this case, the tooth geometry will be controlled by the fabricator's tooling.  Your model does not have to be accurate.  Define a tooth section and a helix off to one side of your gear, matching the worm.
   The other possibility is that you are casting the worm wheel, in which case you do need accurate geometry.  I have not tried this.
               JHG
