convert measured air flow to lb/hr of steam
This is the scenario:
In the lab we have measure the flow of compressed air across a valve to be 1200 SCFH. The inlet pressure (Pinlet) is 34.7 psia. The outlet pressure was 14.7 psia.
My question is how would one calculate what the flow of steam would be across the same valve, with the same inlet and outlet pressures, assuming saturated steam?
