Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
LACHANDARA (Mechanical)
19 Aug 11 16:00
I was wondering if anyone knows if you can get a flexible pto shaft I found one on a seed sprader during my search and I have included this site here just to give an idea what i'm talking about.
[PDF] Broadcast Seeder/Spreader 3-PT. MOUNTED PTO DRIVE ATTENTION ...
www.worksaver.com/Manuals/us33.pdf
However I have not found much more information and i'm no expert by any means in this area. so any one who may know a bit on this, greatly appreciated.
regards.
Helpful Member!  FreddyZ (Agricultural)
22 Aug 11 10:54
I'd say a flexible shaft is more of a last resort, suitable mainly for very light loads. Typically used for higher speeds and lower torques - such as a Dremel Tool. Is there a chance you can deliver power through another means, say, electrical or hydraulic power?
IceStationZebra (Mechanical)
23 Aug 11 22:23
I agree with Freddy. ISZ
SAITAETGrad (Aeronautics)
26 Nov 11 17:02
I'm familiar with these.  They are reliable and simple.
Gyroplane homebuilders love these for spinning up their rotor blades
Never seen them used on farm machinery but if you have a tractor with two sets of hydraulics already being used and the PTO there but can't drive with a conventional PTO shaft...definitely is a good option.
Check out the heavy duty ones on the bottom of the page:
http://www.mcmaster.com/#flexible-drive-shafts/=f3u7ef
12 Dec 11 8:53
The beastiest one [6426K94] at 950 in-lbs max, can deliver about 15 HP at 1000 RPM.
Depending on the loading of the seed spreader, that might do the trick. Try to minimize the bends, and use the maximum radius possible for any bends.
Close Box
Join Eng-Tips® Today!
Join Us             Close
