control joints for blue stone pad over concrete.
Have to install a 30' x 20' bluestone patio. The bluestone are approx 1" thick in different size squares and rectangles. Plan on mortaring them on concrete pad in a random pattern. Not sure exactly how to consider possible control joints. If I poured a 6" concrete pad with either #3 rod or wire, could I get away with using no control joints? My thinking was if any shrinkage cracks did develop, it would happen early and the reinforcment would keep them from getting any bigger so it wouldnt effect the mortared bluestone. Not sure if I'm safer breaking it into 4 equal sections with a metal key type joint and cutting a neat saw blade width joint over exposed bluestone. Also wondering if I put dowels through the metal control joints, I wouldn't have to cut any joint on the exposed bluestone.
RE: control joints for blue stone pad over concrete.
If I didn't use any control joints, what could be the possible outcomes?
Your method of laying the stone over a concrete slab is considered the "Cadillac" option. The contractor in the link you attached lays pavers and stone over a compacted granular base. I have done it that way with pavers, using cement stabilisation, and had a successful result. The varying thickness of the stone would make it a bit tricky.
