Make a reference plane visible in draft drawing
Dear All,
I could not find a way to make reference planes appear in a draft drawing.  Is this possible? (actually, I want to make only one specific plane visible from an assembly, and use it for adding dimensions).
Regards, MT
RE: Make a reference plane visible in draft drawing
Yes, you can do this. Right-click on the drawing view you would like to display the plane in. Then right click on the solid body/part that contains the plane and select "list reference planes". Select the plane you wish to show and tick the show box. I believe you have to update th eview, but it should then be visible.
Jason
You might also need to show hidden detail for it.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
