Dry Ice Storage Material
I'm currently designing a box that an aerospace component will be placed in during transport. It must be kept chilled after a stress relieving heat treat process, so it will be submersed in a dry ice bath. My question is.. what material should I use? After doing a little research online, I have found that most commercial dry ice containers are made of insulating foam and some sort of polyethylene. The part is 130" in diameter and is a ring. Thanks in advance!
RE: Dry Ice Storage Material
http://www.rncind.com/
