Procedure to re-rate a pressure vessel
If an operating pressure vessel needs to work at a higher temperature and lower pressure than the originally design,
what's the right procedure to re-rate the pressure vessel?
RE: Procedure to re-rate a pressure vessel
See the national Board Inspection Code, NB-23
OR
API 510 Pressure Vessel Inspection Code:
In-Service Inspection, Rating,
Repair, and Alteration
thanks for your prompt answer.
