Number of Elements through Wall Thickness
Could someone direct me to some literature that will describe how to determine the minimum number of elements that should be used through a wall thickness for different element types? Thanks
RE: Number of Elements through Wall Thickness
Tara
http://tinyurl.com/4ydjg7m
My guess is that it is similar to camera's megapixels I remember reading consumer reports saying 2 megapixels was all that is needed.
Basically run a mesh sensitivity study is the answer. Depending on how similar your problems are you may get a feel for your analysis type and may not need to run these all the time. I typically run a sensitivity and then deploy this as a method for many runs with similar geometries or loads.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
do you just refine to 2x elements and check stress on a number of points or is it more statistical (K-S test)?
For general purposes, this works fine. However, note that stresses do not converge "smooth", but rather in a sawtooth like fashion. This is in contrast to displacements, which do converge "smoothly". Just something to be aware of if the data doesn't show a nice smooth convergence curve.
It is not related to a statistical distribution.
Brian
www.espcomposites.com
