hardness testing
hardness testing
hardness testing
Can you do hardness tests on P1,P3,P4,P5 and nickle piping and tell them apart from the hardness results obtained?
RE: hardness testing
Only Nickel-base piping can be sorted and this would be using a simple magnet, in lieu of hardness testing.
Beyond this, hardness testing will not provide any information relative to sorting the Cr-Mo pipe alloys. You need to sort these alloys by chemical analysis using a portable PMI device.
what about the carbon steel-P1.
please explain the magnet method on the nickle.
The nickel-base piping is typically non-magnetic. Hold a standard magnet against the bare pipe surface. If the magnet does not stick to the pipe surface, it is probably your nickel-base alloy. Also note, a non-magnetic pipe could indicate an austenitic stainless steel as well, however, you did not mention this as a possibility in your original post.
The problem with trying to sort the steel pipes is that the expected hardness ranges of each of those alloys will largely overlap each other.
Aaron Tanzer
www.lehightesting.com
Gotta use an Alloy Analyzer -- X-ray Fluorescence 'Gun' [Niton is the best-known].  Going rate in central USA is about $250-$300 per day, with a tech to run it.
