Sizing for Motor Loads Softstarter and Protective Device
Please help me on how to size / calculate for the required rating of the softstarter and protective device for a certain motor load. Thank you in advance.
RE: Sizing for Motor Loads Softstarter and Protective Device
First off it probably depends on the relevant code, which you haven't stated.
thanks for the feedback.
i.e:
motor specs / Source:
700 HP, V = 4160, 3 phase, 60 Hz
No, i.e. where in the world are you?  What standards and codes apply?
4160V 60Hz would imply the US, Canada or Mexico, maybe other South American countries like Chile that get a lot of their equipment from Canada and the US.
Assuming someone has properly sized the motor, you size the soft starter for the motor you will connect to it. I don't see the issue here. 700HP motor, 700HP starter.
Protective device? Do you mean the fuses or circuit breaker? Generally you will not have much of a choice, when you buy the soft starter, the devices inside will have been coordinated with specific fuses and you usually cannot deviate from those without violating the starter design. this is a discussion you need to have with the soft starter mfrs.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
