Fundamentals of Concrete Beam Analysis Question
Should be pretty simple question. I just never thought about it before and am curious. See attached image. Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Fundamentals of Concrete Beam Analysis Question
The serviceability design is based on a triangular stress block with a maximum stress dependant on the applied loads.
Both assume a cracked section with the concrete taking no tension, and ignore the compression steel.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
