Section Arrow Moved
Section Arrow Moved
Section Arrow Moved
I am having a perplexing problem with Solid Works drawing.
I cut a section thru the middle of a symmetrical assembly. The
resultant section view has many dimensions and nomenclature attached. Somehow, the section line has moved from the center of the assembly. Has this happened to anyone here? With Catia V5 you are able to select the offending section line and reposition it. Is there a similar fix for Solid Works 2011? Thanks in advance.
RE: Section Arrow Moved
Right click on the Section Line (Cutting Plane Line) and select Edit Sketch, then add a Coincident constraint to it and a central element of the assy.
Thanks to all for solutions.
CorBlimey, your suggestion worked.
Thanks much!
