Forcing view updates
Is there a setting that forces views to update before plotting/printing? I just got a message from our shop letting me know that the numbers on some of our prints aren't working out. I checked the model and everything was fine, but found that the drawings had been printed with outdated views.
RE: Forcing view updates
You can also set this in customer defaults.
Or if you make use of templates, adjust this setting in the template part (and save it).
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Until the designers get in the habit of regenerating every drawing sheet before they plot and save, you need to have th forced regen on.
Maybe Siemens could force a regen when the drawing file is saved or plotted? That would help prevent out-dated data from getting out.
Ben Loosli
