Help on running old FEMAP v9.2 in Windows 7?
I have been running dongle licensed FEMAP v9.2 and NEINastran v8.25 in Windows XP for years. I just upgraded to Windows 7, and am having trouble getting them to load/run. Has anyone done this recently and have helpful advice to share? Thanks in advance, and I can give more details on the problem if anyone thinks they can help.
RE: Help on running old FEMAP v9.2 in Windows 7?
tg
I agree with trainguy that it i s good idea to upgrade. But if that for some reason is no option I think we need som more info.
It's it a 32 vs 64 bit problem? What exactly is the problem?
/Thomas
I am running 7 64 bit.
So - I can install FEMAP and I get no errors. However, when I try to run it, I get an error saying 'Error accessing the security device...' and another one saying 'This version not compatible with windows NT terminal server. Only the networked licensed version may be run on terminal server.' This is really two problems, because if it was just the key, it should open in trial/demo mode. I don't know.
The solver/editor actually runs and solves the <300 node test deck, but the dongle software doesn't so it acts like I don't have the key (demo version).
Have you gone through this before? I haven't dug into xp mode yet, but that is where I am heading. Just was looking for anyone who had been through it before and found a solution.
tg
Have you tested Femap without the dongle installed? It can be that it finds the dongle but something is wrong in the communication, hence an error. If you havent tried it, remove the dongle and test that.
Also, download the latest version of the drivers for the dongle.
If that doesn't work, contact Siemens or your reseller. But the simple solution is probably an upgrade.
/Thomas
However, FEMAP still thinks I am running 'terminal server' and says that is not allowed for the standalone version. Not quite sure how to fix this yet, but you definitely got me closer.
I don't suppose anyone knows how to trick a program into not thinking it is running on a 'terminal server'?
