How to change font in Part list table??
Could somebody please show me how to change font in part list table ( draft mode)?
Thanks in advance
RE: How to change font in Part list table??
Thanks for the reply.
But it changed in the pop up window only not in my drawing.
It's in the Table Style settings, but you will need to have a Text Style created for whatever settings you want.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
"Table Style setting" where can i find it??
I am using ST3. I ran into this before but now i can not find it any more.
Click the View tab then Styles.
In there you will see a drop-down to select the type of style you want to modify (Dimension, Table, Text, Fill etc)
If you want to create a new text style for your table this is where you do it.
Then select Table style from the drop-down and you can create a new table style or modify an existing one. You can set different text and line styles etc.
Its a bit tedious doing it this way, but in ST4 I think its all configurable in the table properties command.
bc.
Quadro FX4600.
