Help ! can some one help identify this !!!
I found this material on my land and i would like to find a use for it. It is magnetic and heavy (in the iron family ) it doesn't seem to rust though. I had 2 pieces analyzed and they  came back, the first
1) 73% fe, <0.003 C and the remainder is oxygen other metals ARE  MANGANESE .43 silicon .76 al .65 the res is trace amounts.
the second 2) fe 65% .001 C, MANGANESE.34 silicon 2.6 al 3.08 titanium .24 the rem is oxygen
I would like to sell this if i can ,and i would really like to know what it is. I can also upload the analysis sheet if necessary.
thanks in advance
Geno
pictures
http://files.engineering.com/getfile.aspx?folder=5ebfb781-3d32-4c38-93fb-2fab438a4f56&file=Picture_102.jpg
http://files.engineering.com/getfile.aspx?folder=525a0db8-d93b-4173-b590-13f6aba449c2&file=Ore1.jpg
http://files.engineering.com/getfile.aspx?folder=498e1522-3681-4e8e-8034-761cbe26bd44&file=Ore2.jpg
RE: Help ! can some one help identify this !!!
Looks like iron ore. Use it for landscape rock.
You named the pics Ore1, Ore2. hmm.
65% and 73% Fe. That has to be iron ore. smile
peace
Fe
