Minimum walkway width
I'm looking for a reference for the minimum walkway width required for a bulk storage rack in an industrial building.
Essentially, it is a storage rack with walkway access to higher levels of storage.
RE: Minimum walkway width
Or just irregular service: maintenance or measurement without needing to carry anything wider than 24 inches?
A man will need to use the walk ways to hook up a plate clamp on top of ~8' tall plates.
If two people will ever have to pass each other on it, I would think a good bit wider would be in order.
can you point out the 18" minimum in OSHA please?
