X-Y Coordinates of holes
Not sure if it is possible but I am trying to find a way for UG to tell me the x-y coordinates of various holes I have in a flat piece of steel without figuring each one out myself. If possible, I'd also like to export these coordinates somehow to be used for programming a machine. Any ideas? Thanks
RE: X-Y Coordinates of holes
You can export hole coordenates to an excel sheet.
In the main tree, right click export as excel spreatsheet.
I have donde this time ago, I think in manufacting module,
program main tree.
In the Drafting module there is a Hole Table function which will create a tabulated note showing the hole locations and sizes. And if you really would like this information in a spreadsheet form, you can select the Hole Table note, press MB3 and there will be an option to 'Edit using Spreadsheet' which will place all the information in the Modeling spreadsheet where you can edit it and/or perform a Save As which will allow you to save an external (non-associative) spreadsheet which can be accessed outside of NX for any purpose needed.
To find this function, while in the Drafting module, go to...
Insert -> Table -> Hole Table...
...and when the dialog comes up you will be asked to select the origin for the holes (the 0,0 point from which the X, Y values will be taken) as well as selecting the options for defining which holes to include in the table and then of course a location for the table itself.
Anyway, give it a try and see if this will work for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
John R. Baker, P.E.
Industry Sector
Cypress, CA
On "ugii_env.dat", the variable
UGII_DRAFTING_HOLE_TABLE=1
or in windows,
Variable name: UGII_DRAFTING_HOLE_TABLE
Variable value: 1
There has been discussions to enable this by default, but since it's not as associative as users might expect it to be (you have to delete the Table and recreate it if there are certain, but not all, types of changes made in the size, number or location of the holes) it was decided to leave it OFF unless someone asks for it and they're told about the limitations (consider yourself having been so informed).
John R. Baker, P.E.
Industry Sector
Cypress, CA
