Composite Joist Vibrations
Does anyone have any design guides or literature on vibrations of a composite joist system (on bearing walls)?
All of my vibration literature covers composite beams and non-composite beams/joists, but nothing seems to cover this type of system.
RE: Composite Joist Vibrations
Design Guide 11 from the AISC and CISC uses a deflection criteria to find the floor systems natural frequencies (joist/beams, girders and combined)
I would assume that the wall (your girder) does not delfect therefore you only have to worry about the composite joist's properties.
hope this helps
Non-composite joists are treated as "composite" when it comes to determining I for vibration calculations in AISC Design Guide #11, so I would just follow along with that and ignore the studs to start and see where that gets you.
I seem to remember SJI had a program for a couple hundred bucks for vibration, pretty old and basic DOS type thing. Been a long time since I designed a joist floor...
Get FloorVibe.
Also, read Design Guide 11 Sections 3.2 and 3.6.
