Model Display?
Model Display?
Model Display?
Does anyone else have a problem with ProE when they are rolling the model tree backwards & forwards to see effects of changes etc?
The problem being is that the model jumps out of the display, and you have to refit it to get the model in view. Then you cant see the model changing?
This is very annoying, to say the least. Surely there must be a setting to stop this happening?
Please help
RE: Model Display?
Check your model size as you roll the model tree forward or backward.  This happens to me when I have large sketch references such as a very large radius to define curvature of a feature.  Any datum created afterward (as well as the default datums) will automatically adjust to fit the entire reference and the model size will jump around significantly and therefore the zoom center of the model.
Hope it works out as that was a pain when it was happening to me.
- J -
