Export Assembly
Export Assembly
Export Assembly
Is there an option to export an assembly to another file?
In my folder, I currently have many parts that I no longer use and have deleted from the assembly.  However, those parts are still in the folder, despite not being used.
I would like to export my assembly to another file, and bring along all the associated parts, to help me clean up my files.  Rather than deleting all the files I don't use, is there an easier way to do this?
Chris
NX 7.5
RE: Export Assembly
You could try using the UGZip utility which I've attached a 32-bit Windows version of.  Despite what the readme file might imply, this works even with NX 7.5 on Windows 7.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
RE: Export Assembly
It doesnt seem to be working.  I dont seen a export->zip option.  I used the help-> nx log to make sure the environmental variable is correct and its there.
I'm using UGII_USER_DIR%.  Should I try UGII_SITE_DIR% or UGII_VENDOR_DIR instead?
RE: Export Assembly
It should show up in the NX menus as...
File -> Zip Assembly...
Once zipped, you can then drop the zip file in a new folder and upzip it to there and you'll have a clean copy of the assembly and its files all in one place.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Export Assembly
John,
forgot about this thread but I got this working.  However, the zip option is under Orphans->zip assembly.
I'm having a problem using it though.  When clicking the "..." buttons, it exits the utility.  Is it supposed to do that or is that an error?
Chris
RE: Export Assembly
I didn't write it so I don't know.  It works fine for me, but I only use is once in awhile.
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
RE: Export Assembly
Hi CPaul,
I remember an utility exe (similar to change part units) written by ugs long back which if run with assembly name will list the of sub-components and parts beneath it. Check in documentation.
RE: Export Assembly
You're thinking of 'ugpc.exe', which can still be found in the UGII folder.
For a description of what this 'utility' does, simply execute it with the -h argument, which will show:
 UGPC Help: ugpc takes the following arguments:
 <part1> <part2>
    This argument specifies one or more part filenames to produce a listing
    for.  This is the only ugpc argument that is not optional.
 -n
    This optional argument indicates that ugpc should print the number
    of components found at a given level.
 -s
    This optional argument indicates that ugpc should print an indented listing
    of the assembly structure.  If a number is specified immdediately after
    the -s (e.g -s4) you can control the amount of the indentation,
 -p<directory1> -p<directory2>
    This optional argument provides a way to specify one or more directories
    for ugpc to search for components in.  The directory must be specified
    immediately after the -p without a space (e.g -p/parts/released)
 -a
    This optional argument specifies that the assembly should be reported
    `as saved'.  By default, ugpc will attempt to search for components in
    directories where the top-level assembly or its components have previously
    been found.  If this option is used, ugpc will not attempt to do this.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: Export Assembly
Thanks much John,
Does this not solve the problem of Cpaul.
RE: Export Assembly
After searching for "ugzip" I saw that some people were having problems with it as well.  They resorted to using the clone assembly feature which seems to accomplish what I need.
Thanks for the suggestion basenxuser, I'll try that out when I get the time.
