Welding both ends of the lintel to bearing plate
I have seen projects by other engineers where the lintel is allowed to welded at both ends to the bearing plate. Personally I like the "rigid" connection only one one side (unless I have lateral/torsional loads). How to do the senior head here approach this issue.
RE: Welding both ends of the lintel to bearing plate
Hope that helps.
Structural Design Engineer
New York, NY
