Solid Edge ST4 - now available for download
For those not privy to the GTAC SE forums, Solid Edge ST4 *English* is now available for download from:
    http://ftp.ugs.com/download.php
RE: Solid Edge ST4 - now available for download
If all goes well I will have my dirty little paws on the new release tomorrow morning. I will spend the next few evenings testing and playing around before doing a complete company upgrade.
Solid Edge ST3 MP6 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
I'm on Maintence, how do I access the gtac forums?
-av8errr
Solid Edge ST3 MP5
xw4600
3GB RAM
Core2Quad CPU 3.00GHz
NVIDIA Quadro FX4800
If you don't already have one you will need to create a WebKey account.  If you only want access to the forums select the BBS Only option.  If you want a full account select Standard.  If you select Std you will need both your Sold-to ID and the WebKey Access Code that came with your software.  If you want BBS Only then you simply  need your Sold-to ID: https://plmapps.industrysoftware.automation.siemens.com/webkey/chooseProductLine.jsp
Go to this page: http://support.industrysoftware.automation.siemens.com/gtac.shtml
Click the link on the left for Siemens PLM Forums
Select your preferred method to access the forums
Access the forums authenticating with your WebKey account
Start posting away...
See you on the other side winky smile
You need to contact GTAC (which in the US and Canada can be done by calling 1-800-955-0000 or going online at:  http://support.industrysoftware.automation.siemens.com/gtac.shtml ) and they will issue you a webkey ID and password (but only if you have valid sold-to agreement with Siemens PLM Software) which is needed to access any of the behind-the-login area of GTAC, including being able to establish a user account for use with the BBS (AKA GTAC Forum).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
Already had a webkey, just needed the link for the forum.
Thanks to both of you.
-av8errr
Solid Edge ST3 MP5
xw4600
3GB RAM
