Streamline Tube/Strut
I have to model various extruded aluminum streamline tubes. Is the an airfoil number for these? So far all I can find is simple cross-sections with major, minor and wall thickness.
RE: Streamline Tube/Strut
Most of them are simply half round ovals.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
Bruhn has a table of streamline tube sections ... as BE says above, most likely just an ovalised section, rather than a NACA airfoil.
if you're trying to model an existing extrusion, why not grab a piece, or ask the extrusion c/- for drawings of their dies ?
The shapes are definitely not oval and are tear drop. The tubes I'm looking at are COTS for light sport aircraft form aircraft supply companies and not from the extrude/shaper. I was hopeing there was a standard shape or spec for them. However this may not be the case.
if they're extruded, then they've come from some defined shape; ask a supplier.
The MS33534 spec should have all the proportions and relationships you need - but the COTS statement makes me wonder if the extruder may have taken liberties (not followed this spec).  Also the MS is for taking round 4130 and mashing it into a streamline or oval.  Not so constrained dimensionally with extrusion.
Been dealing with the same issue myself, except with GM versus Toyota roof racks - soon to purchase the third set of adapters for the kayak racks.
A "half round oval" is a teardrop shape. it is half round on one side and an oval or ellipse shape on the other.
Illustration of streamline tubing from Wag-aero
http://store.wagaero.com/product_info.php?products_id=14719
description of half oval from WiKi
http://en.wikipedia.org/wiki/File:Oval1.svg
B.E
Isn't the trailing edge "half" a parabola?
For aerodymanic drag eval: check out Hoerner's "Fluid Dynamic Drag". There is a section on streamlined bodies including bodies similar-to streamline and oval tubing sections.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
thruthefence
             "Isn't the trailing edge "half" a parabola? "
It easily can be, I was trying to keep it simple.
B.E.
