Square feet of metal sheet link in drawing
I work with parts made in metal sheets with different sizes. I need to know the area (for paint) of each pieces and I want to link it in my draft. If i change the part the area in my draft update automaticly. If it possible ?
Thank you.
Thank you.
RE: Square feet of metal sheet link in drawing
There are probably several threads on the subject that will surface if you search.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Thank you.
One side = Volume/Thickness
Portion = Use dimensions or create a surface and measure ... depends on shape
