Hole Callout precision
I am using a callout to specify the dimensions of a hole in SE draft using the predefined "hole reference" property text features in the callout dialog box. When doing so, the final callout always has .xxx precision on the dimensions it pulls from the model. Anyone know a way to change this precision on the callout to something else?
I have tried the property text method of changing precision of adding {/@0} or similar to the callout and it doesnt work in this application
RE: Hole Callout precision
In draft, click the view tab, then styles.
Select the dimension style you are using (ANSI, ISO, etc.)
The click modify.
Select the "units" tab, and then change the "round off" field from 3 places to whatever you want.
Just know, that all callouts will now default to 4 places.
I use smart dimension for many of my tighter tol "callouts" for this reason, and have my callouts set at three decimal places.
-av8errr
Solid Edge ST3 MP5
xw4600
3GB RAM
Core2Quad CPU 3.00GHz
NVIDIA Quadro FX4800
-av8errr
Solid Edge ST3 MP5
xw4600
3GB RAM
