conventional thermostat failure modes
I've had (wax pellet?) thermostats stick partially open, and one whose metal frame broke, leaving it open.
Is there a "stuck closed" failure mode to worry about, too?
Dan T
Dan T
RE: conventional thermostat failure modes
TTFN
Chinese prisoner wins Nobel Peace Prize
The stuck closed failure for the wax pellet actuator would be due to diaphragm rupture and loss of the wax fill. Not a common failure mode, but can happen, most especially if the diaphragm gets overheated (but it would take temperatures over 250 to 300 F for that to happen), or lots of cycles at middling-high temperatures.
Rod
I've discovered a few stuck open or broken open, mostly during teardowns for other reasons.
Mike Halloran
Pembroke Pines, FL, USA
http:
thanks,
Dan T
Regarding stuck closed failure mode, and diaphragm ruptures...it's a tricky problem. The best seal for hot water is EPDM. But EPDM is attacked by paraffins (e.g. hot molten wax). So the diaphragm is usually a nitrile rubber, sometimes a Viton or similar. It's basically then a race as to whether the diaphragm rots away due to hydrolysis attack from hot water, or gets dissolved/softened by hot molten wax.
There are some more "modern" designs with a viton diaphragm, and a seperate rod seal or wiper of EPDM.
Oh, another failure mode is a stuck-open one, and happens when the piston is allowed to stroke a little too far, and the diaphragm inverts. Reverting the diaphragm is sometimes possible, but takes a lot more force than the return spring usually has in it. This mode is usually an infant mortality failure (one cycle), unless something else breaks or deforms first.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Was an 80's car.
Regards, Ian
As Pat remarked, fail closed does tend to get immediate attention!
Nick
Ya got that right!
