DB-9 cable length limit
What is it? I need a cable run of around 60 to 80 ft. Will DB-9 do the job or should I convert to something else and adapt at the components? Thanks in advance.
RE: DB-9 cable length limit
TTFN
Chinese prisoner wins Nobel Peace Prize
Down to the nitty-gritty. I have to move a 900 mhtz antena further away from my building in order to get a good reception. But I cannot extend the coax cable as that screws up the reception also. Soooo....I need to run cable fromm the antena base or converter (located a the antena) to the PC (about 80 ft away). It has to be DB-9 connectors or adaptable to that.
The question: how far can I go using the standard RS 232 cable and not suffer. This is low baud rate stuff
Your replies are greatly apprciated.
900 MHz is NOT low baud rate, and if that's what you're trying to transmit on this "RS232 cable," then I would guess about a foot or less.
Isn't the rest of your antenna cable coax? If you can't get it to work, then you're doing something wrong, and you need to get someone with antenna/RF knowledge to help you.
TTFN
This will allow you to run 100' with a higher serial baud rate.
You can get these devices from places like B&B Electronics (http:
TTFN
