Threaded bar and studs
Greetings,
i have a high pressure vessel, the manhole cover was bolted to the manhole flange using 1 1/8" stud, grade b7(or could have been grade L7) here is my question, can i use a threaded bar of the same grade cut to size in place of these studs to bolt this man hole cover?
RE: Threaded bar and studs
