customizing icons
customizing icons
customizing icons
Each time I start UG, the icons are rearranged from where I put them last time. How can I get them to stay where they are so that the next day I don't have to change everything to the way I like it?
RE: customizing icons
If you are working with the same system and same login your Unigraphics session settings will be saved for your login.If you open different parts in the same login you will get the same session settings.Just try this.
Rearrange your button settings as you like, then Preferences->User interface (i dont remember exactly the menu names but it must seem like this) put a tick to the "save layout on exit" command. next time you start UG you must probably find the appereance as you set. You may untick the command to prevent accidental changes to the layout.
caeserean
C.U. Mech. Eng. Dept.
http://www.websamba.com/onderunver
