Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have tons of books, have book marked tons of tutorials, which have helped, but this forum has answered those "impossible to find" solutions. I am thrilled with this site..."
Geography
BrianGar (Automotive)
14 Aug 11 13:44
Hello guys,
A bit of a broad problem, and also a broad question at the minute, but I will refine as I go. I just need to know if this is a viable way to do this at first.
The problem in hand,
Measuring the reciprocating motion of a valve over its full cycle.
Test jig goes like this, a valve, follower, cam, spring, and housing is setup as a jig.
A spring returns the poppet valve to its seat position.
As the rpm increases, at some point the valve will start to bounce. Or not make it back to its seat in time for the next cycle.
I want to measure this. Is this possible?
Thoughts at first,
Attach a low mass linear electronic measuring device to the head of valve, and fix a pickup ring at close location?
Does this sort of sender exist?
Is the resolution good enough?
At the minute, I have 200 cycles per second in mind over say a 15mm distance.
What is the common way to do this?
Perhaps I could go with electrical contact on the seat(not sure this could react quick enough)
What are peoples thoughts?
High speed cameras are big bucks...
Im not really concerned as yet about anything other than if its returning to the seat, or_not at a particular rpm.
BG
MikeHalloran (Mechanical)
14 Aug 11 14:44
If you can produce magnetic discontinuities in the valve stem, you can use something like this:
http://174.129.32.184/patent/US3956973
Mike Halloran
Pembroke Pines, FL, USA
14 Aug 11 14:48
Thats interesting Mike, and something along the lines of what Im after. Light too.
Will look further,
Brian,
byrdj (Mechanical)
14 Aug 11 15:37
How about a proximity probe?
No contacting, but must be able to mount close to a good surface on the valve
14 Aug 11 16:14
byrdj,
Im guessing you can hook one of those to an oscilloscope?
Looking on google there, I presume they can work off two ref points bearing in mind this is a sliding action, and not rotary?
Valve material is Ti If that makes any odds to pickup material.
Thanks a lot,
BG
byrdj (Mechanical)
14 Aug 11 17:01
O scope works good.
The material and size of the "target" on the valve would possibly rule out prox probes, especially if you want the whole 15mm travel for the units I've used.  However there might be some special purpose probes available
the operation is the probe measures the gap between the fixed probe and the moving target
Compositepro (Chemical)
14 Aug 11 17:05
It sounds like you need a fiber-optic interferometer. I know they exist but don't know how much it would cost for the range you need.
You would simply need a mirrored surface on the end of the valve stem.
LVDT technology might work as well.
VE1BLL (Military)
14 Aug 11 17:20
Also, review this previous thread:
http://www.eng-tips.com/viewthread.cfm?qid=289831
ScottyUK (Electrical)
14 Aug 11 17:28
Speak to Balluff's applications guys. I think the bandwidth is your biggest problem, whether laser or inductive, but there may well be something suitable in their range. This one looks like a 'possible' with a 500Hz -3dB bandwidth.
VE1BLL (Military)
14 Aug 11 18:19
If the bandwidth is too high and the motion repeats, then one could sample slower than the cycle time (e.g. like a strobe light).
15 Aug 11 10:38
Thanks folks, as I start searching the aboves, its giving me a lot to think about. No doubt Ill be back with more questions, but for the minute, its all food for thought and taken on board,
regards,
BG
MacGyverS2000 (Electrical)
15 Aug 11 11:40
'Twere it me, I would start out with Compositepro's method... that was my first thought, too.
Dan - Owner
http://www.Hi-TecDesigns.com
IRstuff (Aerospace)
15 Aug 11 11:56
My post from last night vanished sad
Sick makes a variety of laser range measurement units.  This one has 10kHz rep rate and micron level accuracy/repeatability:
https://www.mysick.com/partnerPortal/ProductCatalog/DataSheet.aspx?ProductID=40643
TTFN
Chinese prisoner wins Nobel Peace Prize
Skogsgurra (Electrical)
15 Aug 11 14:19
Can you use a strobe light and just look at it? Like VE1BLL (almost) said.
Gunnar Englund
www.gke.org
15 Aug 11 17:53
Ummmmmmm thats a good point actually... Forgive my ignorance but isnt that simply all I need? Its early days, so buying expensive equipment is a touch out of bounds at this point.
Can you point me towards a suitable light?
Many thanks,
Brian,
15 Aug 11 18:19
It depends a lot where you are. I am in Sweden and know what to buy here. In fact, I use a very old Shimpo strobe light. Powerful and reliable. They have this solid state strobe http://www.shimpoinst.com/dt_326.php which goes to 120 000 rpm - or 2000 Hz. That is what I would look for.
Gunnar Englund
www.gke.org
VE1BLL (Military)
15 Aug 11 19:35
Quote:
(almost)
wavey2 A strobe light was the very first thing I had explicitly suggested in the similar previous thread that I had explicitly referenced above. wiggle !!
jimkirk (Electrical)
15 Aug 11 23:04
Just to simplify things, if all you're interested in is at what RPM the valve begins to bounce, perhaps a microphone or accelerometer and a scope with FFT capability or even a bandpass filter can detect the change in audible harmonics associated with the valve bouncing.
15 Aug 11 23:31
Sorry, Jeff. Didn't read the thread.
Gunnar Englund
www.gke.org
controlsdude (Electrical)
16 Aug 11 13:37
I believe sick has an off the shelf linear type magnetic sensor that gives you an analog position out.  I saw it in a brouchure so its not vaporware.  Never used it so dont know if it fits your needs.  I believe its used on cylinders to give a position analog back to the actual position not just a single point like on most cylinders.
Since its analog not sure if this would be fast enough.
Close Box
Join Eng-Tips® Today!
Join Us             Close
