Wider beam connection (Steel Structure)
What'd your suggestions be for a wide beam connection in a steel multi-story structure? E.g. the column is a box section (Tub 180x180x16) and the beams are HE 400-B. Perhaps, increasing the box section dimensions a solution? Regards
RE: Wider beam connection (Steel Structure)
