Electronic stamping/power of attourney
Hi All,
I will be leaving the country for an extended period of time and I was wondering if there was any way to avoid having to fed-ex documents from abroad.
Could I authorize someone to sign for me similar to a power of attorney? How about electronic stamps?
I have heard that electronic stamps are commonly accepted in the truss industry, how is this?
RE: Electronic stamping/power of attourney
Next question is why the hell would you consider doing so?
Yes you can use electronic signature/seal in some states. Check with your state board.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Follow up with "wet" seal when/where necessary.
Done all the time.
Every state is different, and this is an issue that your State Board will know about and have made a ruling on.
Georgia, for instance, not only prohibits the electron transmittal of official documents, but also prohibits anyone from even sending a plan via email that's got a stamp on it. Seriously. Lots of folks break that rule, but the rule is there nonetheless.
Call your state board, don't trust anything you read here.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
PROFESSIONS AND OCCUPATIONS
(225 ILCS 325/) Professional Engineering Practice Act of 1989.
Most States have this phrase or something similar in the Professional Engineering Act.
BUT - when pushed by a time crunch I have found that ALL/MOST jurisdictions will allow an electronic transmittal if immediately followed by an original. But snail mail takes a week and Fedex costs about $15.00!! When you have 100 guys standing around with their fingers in their ears --- try it....
Just my experience. They know we all work on tight time lines, also.
Back when they required an embossed seal - my embosser broke - so I used a simple wet seal. Guess what?/ The guy reviewing my work was on the board an promptly called me up and explained ALL the FL rules. I said I understood and explained my problem and resubmitted when repaired.
They seem to be very picky - glad they have lightened up a bit.
My own state of MO wins no honors either. Ask a very simple question - they say call your lawyer. Called my lawyer - he says - Ask the State - they wrote the law/statue.
And around and around we go.... I just stick to the "Boy Scout" Rule" - if you are honest and it makes sense - then it is probably OK.
