About to buy an ultrasonic cleaner - which one to choose
Hi!
I am about to buy an ultrasonic cleaner. It is going to be used for fuel injectors cleaning.
It should be a powerfull and efficient cleaner for industrial use.
The capacity should be about 1-2 liters.
I am wondering about:
1) Bandelin sonorex 35KHZ
2) Emag Emmi
3) walker eltronics
What is the best frequency for injector clean?
Which would be as good as ASNU in their injector cleaning machine?
Maybe you guys can recommend me the best to buy.
Thank you!
RE: About to buy an ultrasonic cleaner - which one to choose
This may not help you at all, but I bought a no name cleaner in a nic nack shop a yr ago, it was just 40euro.
Its works great, I use it for everything, it came with no book even. Cleans injectors, carbs, and all other small parts amazingly. The amount of crud that comes out of 'clean' parts always surprises me.
Id imagine any named brand could only be better...
BG
I've had good luck with Sonicor. Branson has been kind of mediocre--they seem to be lacking in power.
