A321-200 Wing top skin corrosion .
During a A320 C chek we found corrosion around gear rib and rear spar fasteners heads between rib 4 and rib 5 , in SRM airbus request to remove fastener befor reworking corrosion but there is no acces to remove the gear rib corroded fasteners adjacent to rear spar , it's my first experience with this problem please if any one have experience about this problem help to find a solution .
RE: A321-200 Wing top skin corrosion .
