Catia Macro Sectioning Direction
Hello All I am using Catia V5 and am attempting to write a macro that increments section cuts along a specified axis and measures the inertial values of each of those sections (but that is another topic)
Using the code that is in the help documentation the sections that are created are only in the Z direction. Does anyone know how to make these sections be taken in any other direction?
JB
JB
RE: Catia Macro Sectioning Direction
The position array can be obtained by using the GetPosition command and it gives an 12 element array that is as follows
iComponents( 0) is the X component of the X-axis
iComponents( 1) is the Y component of the X-axis
iComponents( 2) is the Z component of the X-axis
iComponents( 3) is the X component of the Y-axis
iComponents( 4) is the Y component of the Y-axis
iComponents( 5) is the Z component of the Y-axis
iComponents( 6) is the X component of the Z-axis
iComponents( 7) is the Y component of the Z-axis
iComponents( 8) is the Z component of the Z-axis
iComponents( 9) is the X component of the origin
iComponents(10) is the Y component of the origin
iComponents(11) is the Z component of the origin
Originally the positions 0,4, and 8 had a value of 1. In order to change the direction these need to be changed. I have found that there always has to be 1 of each the x,y, and z components and they all have to be with respect to different axis. If that is not clear (which is a good possibility) please let me know so that I can try to explain it better.
I hope this helps anyone that may be having trouble with this as I was unable to find any information on it.
-J
Is it possible to indicate the name of the original script in the help docs?
Thanks for sharing info. Also, did you manage to measure the inertial values of each of those sections?
Fernando
I am still working on measuring the inertial values of each section. The problem that I am having with that is figuring out how to set each section to the active document after it is created so that the value can actually be read. Any ideas there?
-J
Fernando
I am relatively new to VBA so any help would be appriciated.
-J
