display open bodys
display open bodys
display open bodys
I know how to fix a broken display when the body are cutted and you can look inside tke body, a fit operation is fixing the problem.
Is there another way to get more control of this behaviour a default or a setting ?
Thanks in ad
RE: display open bodys
What you need to do is reduce the so-called 'Fit-Percentage', which is defaulted to 100%.  To change this setting, go to...
Preferences -> Visualization -> View Screen
...and at the top of the dialog section titled 'Session Settings' there is a slider which controls the 'Fit Percentage'.  Try changing this to something like 75% and see if this helps.  BTW, this precentage can be preset use Customer Defaults.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
