Could PVD coating cause surface tempering?
I have a snip blade cutting tool that appears to have been (based on EDS results) plated intially with a pure Ni layer which was then covered by a second layer of TiAlCrN (most likely by PVD process).  The surface hardness of the snip blade was induction hardened to 60-62 HRC.
It's my understanding that PVD coatings have a deposition temperature of around 700-800 degrees F.  My question is how could this second layer have been applied without negatively affecting/tempering the below Ni layer and underlying Fe base metal?
I would very much appreciate any input.
RE: Could PVD coating cause surface tempering?
Have you evaluated or are considering a coupon to confirm if PVD process duration can actually temper the surface?
metengr,
We haven't considered doing this yet but it's a good idea.
The chemical analysis results of the base material seem to indicate 1060 steel grade was used.  However, there are additions of Si (.28 wt%), Cr (.23 wt%) and Mo (.20 wt%).  Could it be possible that this is some sort of modified steel that requires a tempering temperature to be high enough so that the PVD process wouldn't affect it?
coreman73;
I am going to be as straight forward as possible regarding advice, and not guess or assume anything. When it comes to anticipating what may happen because of a particular process, what better way to do this by using sample coupons to confirm your findings. The cost is relatively inexpensive, and it can be defended.
metengr,
That is very true and agree.  I will go ahead and recommend that the engineers take a sample and try this out for themselves.  By the way, this is some reverse engineering that's being done so it's pretty much all going to be a guess anyway.
