Kitchen Cabinet and Appliance Loads
Can somebody help me with a source for psf dead and live loads associated with kitchen cabinets. Specifically, how much do typical modern residential kitchen base and wall cabinets weigh (PSF), the contents (dishes, pots, silverware), and the different countertops. My intention is to add the weight of the cabinets and countertops as a dead load for the design of the floor framing. Is the code specifed live load of 40 psf intended to cover the contents of base cabinets and the things we put on the countertops? Is that a reasonable value? I find very little published on the actual loads and subject. In my opinion, the appliances and wall and floor cabinet contents, are not sufficiently covered by a blanket 40 psf live load. The actual live loads along with the cabinets, countertops, and flooring overstress floor joists, especially when there is a center island near midspan.
Thanks in advance for any useful information and opinions.
Scott
Scott
RE: Kitchen Cabinet and Appliance Loads
I also up the dead load for the floors for these materials, why not locally for countertops? i.e., double the joists in these areas?
!" thick marble or granite can add 10 to 15 psf to the local dead load, and, considering long term deflection, should be considered for performance and serviceability.
Mike McCann
MMC Engineering
Example: Our kitchen cabinets are "floor-to-ceiling" modules, and are attached by bolts to the overhead attic trusses, and by additional bolts to the floor joints over the basement. Walking was causing a noise or vibration in the cabinets, but I found that tightening had to be real carefully done top and bottom: pull "up" too much by tightening the top bolts in the attic and I would be pulling up the floor joists and was lifting the cabinets; leave the bottom bolts just a little bit loose, and the motion and noise would start again.
Even dead loads need to be moved: refrigerator, stove, microwaves, storage and cans and sinks need to get installed. But people will be a heavy load by themselves: Ever seen a kitchen on Thanksgiving morning?
If anyone has a source for kitchen specific loads or reasearch on this topic it would be greatly appreciated.
And yes I have a kitchen, but have no plans to weigh my specific materials, which may or not be representative. I was hoping a graduate student somewhere had worked on this for their research project.
As for floor coverings all the major mfgs have recommendations, tile is 1/600, etc.
Double the joist under the front edge of the cabinet and double the joists under any island to mitigate bounce.
IRC doesn't address the issue. Write to the ICC and suggest that they upgrade the code, or if you work for a municipality suggest a modification. Building codes aren't written in stone; they change to adapt to the times.
No offense, but I don't think you'll find a graduate student interested in analyzing kitchen floors. Here's a thought: Do a finite element analysis of the floor on your own. Probably won't take long.
