add feeds and speeds to a NX cutting tool
Is there any way, to add feeds and speeds
to a single cutting tool on NX CAM? like Mastercam software.
Thanks.
Thanks.
RE: add feeds and speeds to a NX cutting tool
Don't know about Mastercam but yes you can assign to a single tool if it is in your tool library.
From the main manufacturing menu select Tools... Edit Machine Data Libraries... Tool Machining Data tab... Insert... Select tool from library... set data.
